Sketchup 2018 Dutch windmill
Hi, I am trying to build a model of a Dutch windmill which requires a vertical section of it to taper from bottom to top of it. I am not able to draw it. Could someone help with this? Thank you! The shape is an octagon.
Cam
Draw an octagon, extrude it up with Push/Pull, and the select the top face and scale it with the Scale tool.
Or draw the cross section profile and an octagon for a Follow Me path.
Thanks, I was trying the move tool!
You could use the Move tool on the top octagon if you find a cardinal point. Don’t select anything before getting the Move tool. Then hover over the edge of the top octagon and find a place where the edge is not selected. Click and move toward the center.
just walked by these:
Thanks Dave, you are a lifesaver!!!
You’re welcome.
6667916691_cd8f7e3c8c_o
:smiley: :smiley:
Thanks, Jack
