Hi
I am using Sketchup 2016 with Maxwell Plugin. Unfortunally rendering process is very slow it look like CPU is used instead GPU.
My configuration is:
Windows 10 with Intel I5 8GB Ram , Graphic Nvidia GTX 750Ti, SSD256GB.
I tryed Tik/Untick “use harware acceleration” and differnt config in Nvidia Control Panel but nothigh is affecting rendering process.
Thank you very much for your reply
I am new with Sketchup and I did not know this is not GPU render.
Yes quality is very good but for eave for small projects it takes a lot of time:(
Is there any other good Render plugin which you would recommend for sketchup?
I have used Maxwell for the last two years, it is correct Maxwell can not GPU render. I believe they are working on version 4 that will be a GPU render.
