I am trying to install extensions from Sketchucation using the extension store V5.0.8 but all I get is the white screen which says loading and to click the green continue button if page does not refresh. I do that, but nothing changes. Any sugestions would be appreciated.
Hey Rick, are you still using SketchUp 2017 Make? If so, it may be that the old unsupported browser used by it can’t display the window. Have you posted your question in the Sketchucation forum?
Yes, I am still using make. I haven’t posted my question there but I will. Thanks
The user interface windows are basically web pages and unfortunately old browsers sometimes don’t display web pages built for newer browsers. Maybe the developers of the Sketchucation tool will have a solution.
Is there any issue just downloading the extensions from Sketchucation and using Extension Manager to install them?
No. The only problems might be with extensions like a bunch by Fredo6 which require paid licenses because you need the Sketchucation Store tool for license management. Not sure if just having the Sketchucation Store installed is enough. I expect you need to at least be able to sign in to your Sketchucation account.
As @DaveR says you can still download RBZ files from the SketchUcation PluginStore and then install them using the native Extension Manager. But you need the SketchUcation toolset, which also has the SketchUcation menu item Archive Installer [which also works with ZIP files]. The SCF licensing side should still work with it installed, although you might need to manage licenses vis the website rather than through the menu items or defunct ExtensionStore’s dialog. Of course some extensions updated might no longer support a ten year old version of SketchUp… Don’t try to use the ExtensionStore as it’s probably incompatible with your current setup… To avoid annoyance you can switch off the Toolbar and disable any update-notifications etc, as you can’t see them in the now blank ExtensionStore’s dialog ! You’ll just have to check for updates the old fashioned way - manually looking through the PluginStore and posts for announcements etc…
