Sketch / VRay "An images file with the specified name already exists. The render process will overwrite it."
Hi,
I’ve started to get a pop-up with the following message when I run VRay renders: “An image file with the specified name already exists. The render process will overwrite it.”
Why is this happening, and how can I correct it? I’m able to run the renderings after clicking “proceed”, but it’s a nuissance to get this message everytime I run a rendering.
Thanks,
Kent
Check in your render settings where you are saving the file… I’m on holiday and far far away from my computer but IIRC there were options there to change things.
Extension > VRay > Asset Editor
Press the gear and look for render output or file output or etc.
