SK Pro 2025 opening SKP with file path in Chinese
The .skp file failed to open when double-clicked in Windows Explorer but worked if I go File > Open > Select the same file in SketchUp 2025.
Unsure what causes it, I think the Chinese characters in the file path might be the problem, but it shouldn’t be…
upload ur file to see whatsappnd
It has nothing to do with any specific file, see the screen recording
it’s a known issue. Devs are working on it.
This is a common issue encountered by many Chinese users, not only with SketchUp but also with numerous plugins and other software, which may encounter errors due to this reason. I have always recommended that they avoid using Chinese characters for file names and paths, as this is the best solution.
