Hi. i have contour lines from autocad, to create the land. But they are too complex. So i instaled an extention called “Simplify Contours”. it simplifyes based on small angles. For exemple, i tell the extention that i want to eliminate all angles smaller then 10º. So what it does is to eliminate small angles. But by doing so, it creates very small lines with bigger angles.
When i then use those lines with sandbox, it creates a very complex mesh.
So what i’m looking for, is a tool that simplifyes contours based on the length of the lines. For exemple, some extention that eliminates all lines smaller then a given length.
Is there something like this available??
Thank you
