Sign-In Error
We are getting the sign in loop error. Our domain is @springbranchisd.com and mysbisd.org.
Thanks for the post @sbisd and thanks for linking your website in the post too. That always saves me a lot of time. I was able to verify you are a k-12 school and get all the info I needed on your website so I will get you added to the database right now.
In fact, by the time this post goes live you will be all set to deploy the app if you have not already done so. Just make sure you don’t skip any steps as you are deploying the app as that has been known to cause issues like the ones you are currently seeing.
If you are still running into errors after this post is live and are sure you deployed the app correctly, try clearing the cached files and cookies as that is the most likely cause of issues at that point. If none of that helps, @ me on the forums or send me a private message and I’ll see what I can do to get you up and running ASAP.
