Sheet Yield Plugin
Hi,
Is anyone aware of a plugin/extension which could be used for plywood panel sheet yield?
Ideally you would be able to select the faces made from plywood in the model and input the sheet size (2440x1220 in my case) and it would output the minimum number of sheets required to cover this area. (taking into account the shape of the face).
Any suggestions would be appreciated.
Thanks
Search on Cutlist and Open Cutlist.
