Shadows on Elevations
Hi - does anybody know how to show a shadow thrown on a building in elevation, i.e. the building throwing the shadow will be in front of the building in elevation but if you create a section plane for the elevation you lose the building throwing the shadow and thus the shadow! Any suggestions???
The sectional planes can be isolated within a group or component; make the building a group, edit it and drop in the sectional plane - it will only cut geometry within that group.
To add to what @gadget2020 has said.
http://help.sketchup.com/en/article/94995
is article regarding section plane in group.
there are a couple of ‘Shadow Catcher’ type plugins that add grouped geometry slightly off the faces in shadow to avoid z-fighting…
this groups faces have the edges hidden and can then be painted with a transparent black material adjusted to to suit the shadows desired strength…
you can test the principle quite easily with a couple of cubes, and drawn shapes…
john
Thanks gadget2020, I will give that a try!
Thanks Josephkim626!
Thanks john_drivenupthewall. Love the name!
