Maybe I’m missing the proper way to set up toolbars. Short version…as I add toolbars to the large toolset which is 2 columns wide. Any additional toolbars are sized 1 column and only snap below or a space creating 3 columns. Can I position the toolbar as desired?
That’s a normal thing. At least it’s been that way since the current toolbar manager was introduced. For a long time only the Large Toolset has been two columns wide when docked.
FWIW, I find the Large Toolset has too many tools I don’t use often enough to justify using toolbar realestate for so I make two custom toolbars with just the tools I want. Same for some tools across the top. That opens up space for other tools I useIt also eliminates some of the spacers.
The section tools are added to one of my custom toolbars
Thanks, you’re generous with your time and knowledge. I had things arranged nicely in 2026 version, then procedural tools was added to the mix and things won’t fit how I want.
On a semi-funny side note…I thought the new 2027 Colin face me component was holding a black powder muzzle loader. I thought whoa… that won’t last long. ![]()
You’re welcome and thank you.
I figure that as nice as the Procedural tools are, I won’t use them enough in my work for them to justify toolbar space so the menu will work fine.
If I didn’t do tutorial videos I would probably remove more tools from my custom toolbars on the left to free up more space. I’ve been careful to limit myself to two rows across the top and two down the left. It’s a balancing act.
Maybe he’s got a muzzle loader hidden in his pool cue.
