Is it possible to import type faces into layout. My letterheads have been done in -
“The typeface used Gotham in bold.
I believe a similar web safe typeface is Monserrat or something”
Also want it in this blue. Ive used the snipping tool on my letter head to import this text below my logo
DaveR
July 1, 2018, 1:23pm
2
LayOut uses system fonts so if you have the font installed on your computer, you can use it in LayOut. You can adjust the color of the text in the Text window.
As for the logo, do you have it as an image? It’s color will display as it is.
Not sure if i have it on my computer, can you buy or import the font ?
the logo inserted fine it just the rest of the text in that info bar i want in that blue
DaveR
July 1, 2018, 1:28pm
4
I expect you can buy and install the font. Do a search.
As for the color, select the text and then click on the black square in the Text window in the tray on the right. That will open the Colors window where you can change it.
DaveR
July 1, 2018, 1:37pm
6
You’re welcome.
Out of curiosity, in what format is your letterhead? There might be a better way to get the logo into LayOut.
I have the logo as an independant file
DaveR
July 1, 2018, 1:40pm
8
So you can just insert that image into LayOut instead of snipping it from your letterhwad.
But the rest is in a letter head that was created for me
I did that with the logo , its the text i snipped
DaveR
July 1, 2018, 1:42pm
11
OK. Well, you should be able to find a source for the font and use it instead of snipping it from your letterhead.
DaveR
July 1, 2018, 1:50pm
12
I found Gotham is available from typography.com
If Montserrat will work for you, it is available here at no charge. It may already exist on your computer.
DaveR
July 1, 2018, 1:54pm
14
Yes. There are a lot of versions of the font if you get all of them.
cant see montserrat in the option in layout
DaveR
July 1, 2018, 2:02pm
16
It was installed on my computer but maybe not on yours. You can get it from the link I supplied.
I hope sketch up are paying you dave , legend
DaveR
July 1, 2018, 2:05pm
18
This is what it looks like in Montserrat.
Thank you.
DaveR
July 1, 2018, 2:07pm
20
I’d send it to you but until you have the font installed, it won’t display properly.
