# Selection tool very slow to select
**URL:** <https://forums.sketchup.com/t/selection-tool-very-slow-to-select/54783>\
**Category:** SketchUp\
**Tags:** make-2017\
**Created:** [November 9, 2017, 3:54am UTC](https://forums.sketchup.com/t/selection-tool-very-slow-to-select/54783 "2017-11-09T03:54:06Z")\
**Showing post:** 26
**Author:** ![Pitus](https://avatars.discourse-cdn.com/v4/letter/p/6f9a4e/32.png) [@Pitus](https://forums.sketchup.com/u/Pitus)\
**Post date:** [January 14, 2018, 6:47pm UTC](https://forums.sketchup.com/t/selection-tool-very-slow-to-select/54783/26 "2018-01-14T18:47:28Z")
I can’t believe that this issue is still unresolved after 6+ months since it was first discovered (or even earlier, I only found reports as far as July 2017)…
Especially that the problem is only with left-click with the Selection tool - when you right-click on a surface, it gets selected immediately, same with edges and same with unselecting by right-clicking outside the model. you can also right-click and choose various Select menu options and it works instantaneously so there is no problem with SketchUp’s selection functionality only with a left-click for some weird reason (and even stranger is its relationship with Windows Updates or Graphics Card drivers).
Why not check your Selector tool code and make it either detect this weirdness and switch to a work-around (similar to how right-click works just fine now) or just always use a different technique so it works even when Microsoft issues an update or Intel breaks whatever they’re breaking in their display driver.
The only thing I can’t do right now with right-click is select multiple surfaces as it doesn’t respect CTRL+click to add to selection…
I’ve wasted hours Today trying to get this working and I’m giving up, for now, with SketchUp until this is properly fixed (I’ve been an active SketchUp user for many years, since one of the very first versions and this is the first time I can’t use it due to an annoying bug that’s blamed on others instead of being fixed) - shame on you Trimble!
OS - Windows 10 Pro build 16299.rs3\_release.170928-1534
Intel HD Graphics 630 within i7 8700K CPU
SketchUp Make 2017
_[View the full topic](https://forums.sketchup.com/t/selection-tool-very-slow-to-select/54783)._
