Select the lower value from two values
Hello,
please help
see the graph:
https://creator.trimble.com/graph?layout=right&asset=whp:c6204484-ded3-4097-99ae-faed2d45ceea
there are two sides with different lengths that are adjustable (so once can be the right side longer and once the left side) and there is also the parameter “position_in_U”.
Ideally the “max” value of the parameter “position_in_U” should be always let’s say 100 lower than the currently shorter of the two sides…
hopefully understandable
thank you
got it - sometimes the process of forming a question almost automatically triggers the process of forming an answer :grinning:
https://creator.trimble.com/graph?layout=right&asset=whp:88f6b012-f065-4e46-86f9-77ae2795d506
