Solid fills on section planes show correctly in the model, in image exports and during in-SketchUp animations, but are failing to show in exported animations. Graphics drivers are up-to-date, as is SU itself. Any ideas? - Example animation - https://youtu.be/uno_9L9TZBQ
There are errors with exporting animation in 2024. Use 2023 to export and it should work as expected.
: $ maybe they go fix on SU25 at mid of the year
Thanks. So do I just back-save the current file to 2023 format, and export the animation from there, or do I need to install 2023 SU and export from that?
No. Just open your 2024 file in SketchUp 2023.
You will need to install SketchUp 2023 to use it for the export.
What Dave said.
Cheers. Much appreciated. Worked a treat.
