Very new to Ruby. Wondering how difficult it would be to create a script to randomly move the vertices of a sandbox TIN along the Z-axis between -1 and 1 units? Can anyone point me in good direction on where to start? Thanks!
Start here …
Then study examples provided by the Trimble Development team and posted in their Extension Warehouse Store (Example Scripts, Shapes, Utilities Tools, etc.)
Also study open source extension by community members.
@thomthom (who now works for Trimble) created a vertex quantizer example some years ago, that may be beneficial for you to study. (It may have been posted over at the SketchUcation forums. Membership is free there.)
I found the topic thread (that I referred to above) …
… and my posting of the cleaned up code, which I repost below.
As stated in the original thread, the “plugin module” should be wrapped inside some author module.
Use it as an example of how to adjust geometry vertices in SketchUp.
# GridSnap.rb
# by Thomas Thomassen
# THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
# IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
# WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
# This utility quantizes the vertex locations, of the current selection,
# of the model, or just the current context, to a 3D grid, whose interval
# can be set via a popup inputbox.
# Revisions:
# 0.1.0 : 2012-03-26 : by Thomas Thomassen
# initial beta release
# 0.2.0 : 2012-03-26 : by Dan Rathbun
# + Added menu_command() method for inputbox and undo operation.
# 0.3.0 : 2012-03-28 : by Dan Rathbun
# + Revised the menu_command() method to pass a selection set to the
# adjust_vertices() method as a 2nd argument.
module GridSnap
@@last_tolerance = 0.25.m
class << self # PROXY CLASS
def round_point( point, tolerance )
grid_pt = point.to_a.map { |n|
b = ( n / tolerance ).to_i * tolerance
r = n % tolerance
(r > tolerance / 2) ? b + tolerance : b
Geom::Point3d.new( *grid_pt )
end
def test_it
pt = Geom::Point3d.new( 3.976879.m, 3.760209.m, 1.002568.m )
tolerance = @@last_tolerance
grid_pt = round_point( pt, tolerance )
puts "Original: #{pt}"
puts "Tolerance: #{tolerance}"
puts "Grid Point: #{grid_pt}"
end
def adjust_vertices( tolerance = @@last_tolerance, ents = nil )
model = Sketchup.active_model
vertices = []
# determine the context:
ents = model.active_entities() if ents.nil?
# Collect vertices.
for e in ents #model.active_entities
vertices << e.vertices if e.is_a?( Sketchup::Edge )
end
vertices.flatten!
vertices.uniq!
# Calculate grid adjustments.
vectors = []
entities = []
for vertex in vertices
pt = vertex.position
vector = pt.vector_to( grid_pt )
next unless vector.valid?
entities << vertex
vectors << vector
end
# Apply transformations
model.active_entities.transform_by_vectors( entities, vectors )
puts "#{entities.size} adjusted to grid."
end
def menu_command()
title = 'Adjust Vertices'
prompt = 'Tolerance'
default = @@last_tolerance
result = UI.inputbox([prompt],[@@last_tolerance],title) rescue @@last_tolerance
if result
begin
model.start_operation("#{title} (#{Sketchup.format_length(result[0])})")
if model.selection.empty?
adjust_vertices( result[0] )
else
adjust_vertices( result[0], model.selection.to_a() )
end
model.commit_operation()
rescue
model.abort_operation()
else
@@last_tolerance = result[0]
end
end
end
end # PROXY CLASS
#{# RUN ONCE
unless file_loaded?("GridSnap.rb")
# Menu Entry:
UI.menu("Tools").add_item("GridSnap") { menu_command() }
file_loaded("GridSnap.rb")
end #}
end # module
