@CaseyG could I get @olsc.manchester.sch.uk whitelisted please
Hi @StuartTelford and @m.blake. Thanks for the posts and sorry for the delay in my response.
I am happy to get both of you added to our database right away! I just need a few things from you first. First I need to know what you are using to deploy the app (Google or Microsoft). Second, I need to know the domains you want added. Finally, I need to know if you are k-12 schools or are higher education schools. As you already listed your domains, you are already part of the way there so just let me know the rest of what I need and I’ll get it done right away.
Hi Casey,
Can you add the following domains, please? This is in case other schools follow suit and use Sketchup.
Do I have to make separate requests for more domains?
We’ll also be using Microsoft to deploy.
Lastly, being in the UK, it’s for ages 5 to 10, I think you would call it 1st grade through to 5th (sometimes 6th).
Cheers
Stu
Hi there @StuartTelford! Thanks for reaching out. While I am happy to add you to our database if needed, if you are deploying the app via Microsoft it should not be needed. Can you let me know if you have already deployed the app and followed all the instructions for a Microsoft deployment?
If you have and are seeing an error, can you please share a screenshot of it with developer mode enabled and the console tab open? Once I have that I can check the error code and see what I can do to find a solution for you right away.
@tzsavs.tyc.edu.tw Please add my domain to the whitelist.
boss@tzsavs.tyc.edu.tw
