This would be very handy - one more way of managing large numbers of scenes.
Last request was made in 2017 and the thread is now locked:
Is it possible to change the color of the scene TAB? - SketchUp / Pro - SketchUp Community
agreed.
meanwhile you can use emojis. not as good, but it helps a bit
Unfortunately, the Ruby API gives you no access to the scene tab user interface. No colour, font, or styling properties exist on these tabs, so no script or extension can currently be written to recolour them.
What you can do is use Unicode markers like a circle or a triangle or a star or give each scene name a prefix like 0.1, 0.2, etc. You could also do a clear blank scene name in between groups of scene names so that it breaks it up visually.
▲ Sections
● Interior
★ Presentation
Another idea, which will require a bit of coding, is to create a floating scene palette with coloured buttons for each scene. Instead of clicking on the scenes, you’re clicking on a pop-up window.
Screenshot and code below. Please note this is completely vibe coded. Please use at your own discretion.
# scene_palette.rb
# Color-coded scene navigator for SketchUp — a workaround for the lack of
# scene tab colors in the API.
# Install: copy to your Plugins folder, restart SketchUp, then open via
# Extensions > Scene Palette. (Or paste into the Ruby Console to test.)
# Coloring rules (in order of precedence):
# 1. Explicit color tag in the scene name: "Plan {red}", "Section {#3a86ff}"
# (the tag is hidden in the palette but stays in the tab name)
# 2. Numeric prefix, colored by band of ten:
# 0-9 red · 10-19 orange · 20-29 green · 30-39 teal · 40-49 blue
# 50-59 purple · 60-69 pink · 70-79 brown · 80-89 gray · 90-99 gold
# e.g. "05 Plan" is red, "12 Elevation" is orange, "23 Detail" is green.
# 3. No number: auto-colored by the first word, so grouped names match.
module ScenePalette
# One color per band of ten (0-9, 10-19, ... 90-99). Edit to taste.
BAND_COLORS = %w[#e63946 #f4a261 #6a994e #2a9d8f #457b9d
#8338ec #ff6b9d #bc6c25 #8d99ae #e9c46a].freeze
AUTO_COLORS = %w[#e63946 #f4a261 #e9c46a #2a9d8f #457b9d #8338ec
#ff6b9d #6a994e #bc6c25 #118ab2].freeze
def self.color_for(name, index)
if name =~ /\{(#[0-9a-fA-F]{3,6}|[a-z]+)\}/
Regexp.last_match(1)
elsif name =~ /^\s*(\d+)/
band = Regexp.last_match(1).to_i / 10
BAND_COLORS[band % BAND_COLORS.size]
else
prefix = name.split(/\s+/).first.to_s.downcase
AUTO_COLORS[prefix.sum % AUTO_COLORS.size]
end
end
def self.display_name(name)
name.gsub(/\s*\{[^}]*\}/, "").strip
end
def self.build_html
model = Sketchup.active_model
pages = model.pages
current = pages.selected_page
buttons = pages.each_with_index.map do |page, i|
color = color_for(page.name, i)
active = (page == current) ? "active" : ""
label = display_name(page.name)
"<button class='scene #{active}' style='--c:#{color}' " \
"onclick=\"sketchup.select(#{i})\">#{label}</button>"
end.join("\n")
<<~HTML
<!DOCTYPE html><html><head><meta charset="utf-8"><style>
body { font: 13px system-ui, sans-serif; margin: 8px; background: #222; }
.scene { display: block; width: 100%; margin: 3px 0; padding: 7px 10px;
border: none; border-left: 14px solid var(--c); border-radius: 4px;
background: #333; color: #eee; text-align: left; cursor: pointer; }
.scene:hover { background: #444; }
.scene.active { background: var(--c); color: #fff; font-weight: 600; }
.refresh { margin-top: 8px; width: 100%; padding: 5px; border: 1px solid #555;
border-radius: 4px; background: #2b2b2b; color: #aaa; cursor: pointer; }
</style></head><body>
#{buttons}
<button class="refresh" onclick="sketchup.refresh()">↻ Refresh</button>
</body></html>
HTML
end
def self.show
@dialog ||= UI::HtmlDialog.new(
dialog_title: "Scene Palette", preferences_key: "scene_palette",
width: 220, height: 420, resizable: true, style: UI::HtmlDialog::STYLE_UTILITY
@dialog.add_action_callback("select") do |_, index|
pages = Sketchup.active_model.pages
pages.selected_page = pages[index] if pages[index]
@dialog.set_html(build_html) # re-render to move the highlight
end
@dialog.add_action_callback("refresh") { |_| @dialog.set_html(build_html) }
@dialog.show
end
unless defined?(@menu_added) && @menu_added
UI.menu("Extensions").add_item("Scene Palette") { show }
@menu_added = true
end
end
ScenePalette.show
