Scale dimensions
Hi, I’m working on a plan and my scale is supposed to be 3/4". When I click on an existing dimension, it says it’s set to 3/4", but when I create a new dimension, it gives me the correct measurement. The problem is all my plans are like this—do I really have to redo everything?
Someone can help me ?
Where have you set this scale?
Share the file so we can see what you are working with.
my file is too heavy…
Upload it to DropBox or We Transfer and share the link.
Which dimensions are a problem? Why have you manually selected the scale for the dimensions?
I selected the dimension and realized the measurement was not correct.
So far I’ve only looked at the sheet showing the fireplace views and the SketchUp model. Your viewports do not reflect the scene iun the model. In fact all four viewports are linked to the same scene.
This is the scene in SketchUp:
And the four viewports in the LO file.
As far as I can tell you haven’t created scenes in the SketchUp model for the elevation views of the fireplace. You need to do that. It appears that you are also trying to use camera clipping (which is the bug) instead of suitable section cuts. That would account for the dimensions not anchoring to the model.
Since your dimensions aren’t anchored to the model, any errors in those dimensions would be due to inaccurate placement of the dimensions when you put them in.
I guess @ateliernab will have more for you so I’ll leave it in his capable hands.
not really, I was gonna ask where the problem was exactly, because I’ve poked around in the file, and I see viewports at 1:16 and other at 1:32 and then the dimensions follow the same logic…
I might need @design.kg.vf to point at the problematic view here.
(but right now I’m expected at the train station)
also, it’s oddly smooth for a 1gb layout file. navigation is just clean and all…
The dimensions aren’t anchored to the model and as such most don’t accurately reflect the dimensions in the model.
@design.kg.vf rather than add more scenes in your model I copied the fireplace into a separate SketchUp file and created the elevation views. Here’s a viewport from that model in your project. With dimensions set to Auto Scale they go in fine and reflect the dimension in the model.
The bug I see if it is a bug is that LayOut isn’t showing the dark background and Reset button in the SketchUp Model panel for your viewports. If I modifiy the camera in one of the viewports I added from my model, the SketchUp Model panel shows the override correctly.
By the way, last year in February we talked about the problems associated with overriding the scene Camera properties.
This LO file exhibits the same problems I thought we’d fixed then.
Here’s the kind of mess not using scenes correctly and overriding Camera properties makes in your LO file.
