Heyo Devs,
I’m quite new to sketchup extension programming (and ruby as well) so please excuse me, if the answer to my question is obvious… but I think it’s not. The search didn’t help either.
I implemented an extension in oop style. Is there a way to attach my custom objects (and their states) as attributes to the sketchup-model so it gets saved within the .skp file? What possibilities do I have to save anything within the skp? In my case, my objects for example hold lists of faces, so after saving and loading the model, this list should still work. Any ideas before I start hacking a workaround solution?
Thanks in advance + Cheers,
Sebastian
The answer is in your question Put your data into the model attributes.
Haha I didn’t expect that to work, so I didn’t even try. I supposed only built in classes would work with that… Got to try that
Well, you can’t attach everything, but almost. Take a look at this : [Info] Allowable Classes for "set_attribute" • sketchUcation • 1
Hum according to your posted link exacly what I’d need, e.g. a list of entities (faces) is not possible
Well, you can attach stuff to the faces themselves.
What is it exactly you’re trying to do?
Only group and component instances can have permanent GUIDs.
If your faces are not grouped, then you must assign some kind of id attribute into a dictionary, and rebuild your lists after the model is re-opened. Actually just the presence of a certain named dictionary is enough for collecting them. (You need to attach a custom Sketchup::AppObserver
subclass that then triggers the rebuilding.)
mdl = Sketchup::active_model
ents = mdl.active_entities
all_faces = ents.grep(Sketchup::Face).find_all {|face|
face.attribute_dictionary("soundglider") != nil
If you need to collect any nested faces, then you iterate the model’s DefinitionList
collection, checking each Sketchup::ComponentDefinition
instance’s entities
collection, but only if the defintion’s instances
collection has a size > 0
. (Groups are a special kind of defintion, so they are also in the defintion list.)
Thank you very much, now I can imagine how I solve my saving problem. The hint with the AppObserver is very useful!
