Saving components and importing into other files/drawings?
As a bit of a rookie (v much a rookie) I have previously used groups for almost everything, rather than components.
99% of my work is in-frame kitchen design/manufacture, and as such I frequently find myself designing the same unit again and again (600mm belfast sink unit being the prime example).
I have been trying to save the unit (inclusive of carcase/faceframe/doors/sink all saved as groups during drawing) as a component in a folder I have created so that in future I can just import the unit rather than re-drawing.
For some reason, once imported into my drawing, the drawing itself is invisible- only the blue box framing the component is visible? Eh!?!
Any tips on how to create, and more pressingly, use a catalogue of units I can build up over time would be great!
Thanks in advance!
Pete
Make each of your groups into a component (or better, a hierarchy of components, eg, sink unit, sink, counter top, cupboard base/base side/base back/base bottom/kick plate etc). Give each one a meaningful name.
Then select one top level component and Right click and choose Save As… , give it a file name, and change the folder name if needed.
In a new drawing, just choose File/Import, pick the component, and (re)use it.
You can do the same with sub components too.
