Save to svg file
If the drawing is flat, you can use “Export face” feature in OpenCutList.
But your drawing is not only flat. It contains a lot of edges (quite too much) and no closed face on the main guitar body.
So you have to improve the drawing to be able to export to SVG with OpenCutList.
This model would be better :
tekening ovalen klankgat OM.skp (1,1 Mo)
Else, you can find more infos to use OpenCutList to export to Shaper Origin here.
Indeed, tgis drawing is much better. The ornaments on the side may be removed, i don’t need them. The most important for me is the soundhole of the guitar.
But how come when i download this last drawing, i do not get it? It’s always my original drawing.
Thanks all 4 the help
This should be a better drawing. (I hope )
But when I zoom in on the contour of the fuitar, they are all straight lines. How can I make them smoother, as in round?
tekening ovalen klankgat OM.skp (165.3 KB)
i v made some adjustments that I think will be better
tekening ovalen klankgat OM.skp (172.9 KB)
Can you please show me on a tuturial how to save this drawing into an svg file? It just dont work for me :frowning:
Thnx
As mentioned several times: you need to fill empty faces to be able to export their outline as SVG.
And in this case, you will be able to export this kind of SVG :
guitar.svg.zip (3,8 Ko)
thanks so much.
But unfortunatly, I still don’t known how you did it.
Christof
Just redraw one edge of guitar outline and it should recreate a face.
but in the last drawing, everything was closed line?
Closed line, yes. But without a face to join them.
Change the display “style”. And you will see that the guitar body background is not filled.
thnx for all the help
