Sample and apply not showing texture - only color
My texture sample tool will only sample colors from the texture item I click on. I’ve visited the styles tab and can’t find a setting to adjust that changes this. My sizing is normal (inches) and not oversized as I’ve seen with others who have apparently had this problem. I’m new to this.
On a Mac that is the proper behavior for the eye dropper on the materials palette. You need to hold command while using the paint bucket to sample SketchUp materials - you’ll see an eye dropper appear and then you can sample around your model.
To elaborate… the sample tool on the materials pallet samples RGB value of a single pixel you click on, color only. However it does do anywhere on the screen, useful for matching colors in other open programs or on an open browser window. @bmike has pointed out how to get to the proper materials sampler tool.
Thanks so much! Appreciate the help.
Tick the little ‘solution’ box on my previous post. Helps others quickly find solutions and lets people know that this is solved.
