SamFw Tool 6.0.1 Download Free Latest Version 2026
Software Name : SamFw Tool
File Size : 112.40 MB
Version: 6.0.1
Developer : SAMFW
File Type : Zip
Compatible : Win 7 / Win 8 / Win 8.1 / Win 10 / Win 11
Download SamFw Tool :backhand_index_pointing_left:
What’s New in SAMFW Tool v6.0.1
SamFw Tool 6.0.1 - Add 12 firehose loader, Fix error Chunk too large, some bugs
SamFw FRP Tool version size
Main function:
Remove FRP with one click
Change CSC with one click
Remove FRP for new security patch (Aug 2022)
Remove FRP paid method
Read info, Factory reset, Reset FRP
SamFw FRP Tool is window based software that is used to bypass the FRP mostly in Samsung’s all models. This tool is now used for firmware flashing efficiently with just a few clicks. Also, The SamFw FRP Tool uses ADB (Android Debug Bridge) mode, which is a secret method for getting your device back on the Google account.
Why Choose SamFw Tool?
SamFw Tool 6.0.1 is a useful tool for bypassing FRP locks on Samsung devices. Its simple and user-friendly interface makes it easy for both beginners and technicians to use. The tool supports many Samsung models, helping users regain access to their devices quickly and efficiently.
Version 5.4 also offers improved speed, better error handling, and enhanced diagnostic features. Also, These updates make the FRP bypass process faster, smoother, and more reliable for Samsung users.
Key Features of SamFW Tool
FRP Bypass
The SamFw FRP Tool removes the Google account from Android smartphones and makes it new for users.
Security Patch
This tool is redesigned for Samsung firmware for all versions. Therefore, it supports the latest security patches for all Samsung models.
ADB-Based Operations
ADB ( Android Debug Bridge) is a mode to bypass the factory reset protection in Android. Also, It works to connect pc with an Android to repair mobile phones for this purpose.
Faster and more Efficient
This tool offers quick and more efficient services to repair Android smartphones. You can remove restrictions from Android in a few seconds.
Additional Android Utilities
In this tool, robots are incorporated to make this process quicker and more efficient. Additionally, it is also more flexible than other tools.
Device Detection
The tool uses an auto system to detect devices for repairing the system. You can flash firmware or remove FRP. It is also automated by this tool.
Real-Time Logs
You can push a live comment to solve the problem and get help at the time. Also, You can detect troubleshooting on time and to comment to remove.
Enhanced User Interface
If you are a beginner or an experienced user, you can use this tool in just a few clicks. Due to its light weight, this tool performs quickly. So, It has a simple dashboard to operate the system.
Pro and Cons
Pros:
SamFw FRP Tool is available for free use.
The tool works well for FRP bypass on older Samsung phones.
Also, This version performs FRP bypass quickly and improves work speed.
The tool is easy to use and usually detects devices without problems.
Cons:
The tool may not work well on new Samsung phones with updated security.
Security bypass tools can be misused and may create privacy or data risks.
On some devices, the FRP bypass process may fail or stop, requiring repeated attempts or extra manual steps.
I don’t follow exactly, what do you mean?
But just in case :
You can change the camera parameters of any scene by right clicking the scene and choosing update.
That will ask you which current setting you wish to update in the scene.
:+1: thanks
What version of SketchUp are you using? Your profile seems to show conflicting information.
There really aren’t multiple cameras in SketchUp. Scenes are used to define positions of the camera within the model space.
It isn’t clear from your forum profile or posts whether you are using the free web version or the 2018 desktop version of Sketchup. If you are using the latter, there are several extensions available that allow you to save and restore camera properties. The web version does not support extensions, so your only option is to use Scenes or the Camera previous/next commands.
There is a so-called “camera history” accessible via the “Camera Previous” (which has an associated icon) and “Camera Next” commands. (Similar to Undo/Redo)
However, I have no idea how many camera positions it stores, and I wouldn’t remember anyway whether I needed the view from five or ten steps back.
It is far more practical to use scenes, or extension. :wink:
I think it’s 5, but it can feel like less than that :
star in position A. scroll a bit. stop, then rotate. this counts as 3 already, the current camera, the one pre rotate, and the initial one.
I’ve used it after zooming out inside a wall by accident, but never more than 1-2 step back.
So you could just go back through dozens, hundreds of previous camera instead of just hitting the scene you saved for the exact camera position you wanted?
To DaveR’s point - the solution we provide that will work is dependent on the information you provide in your profile - which currently conflicts by showing both Web and Desktop. Fix this info first.
If on desktop (ie SU Pro) you can try the Advanced Camera Tools Extension. This lets you create a ‘physical’ camera in the scene (and add them all to their own tag so you can toggle them on and off). To access a specific camera, you can right-click and choose ‘Look through camera’. Note this will still create and utilize scenes for each camera but will give you an alternative way to toggle them on and off so to speak.
