A client of mine faces a peculiar issue -the exact same SKP file performs fine on older hardware (AMD Ryzen 3800X, 32GB of DDR4 RAM, 4070 Super) yet is super laggy on newer, much more powerful hardware (AMD Ryzen 9950X3D, 64GB of DDR5 RAM, 5070 Ti 16GB). Graphics options are the same, both computers have fresh Windows 11 Pro installations, both use the latest Nvidia studio drivers and the latest available Sketchup 2026 build.
I’m at a loss here -the new computer performs as it should on other applications. What could the issue be?
AMD Ryzen 9950X3D has integrated graphics - we’ve seen users who have connected their machine to the wrong displayport/HDMI and end up using this instead.
Users with multiple displays are always more prone to issues also. Use just a single one whilst troubleshooting.
Visit the windows graphics switching settings, the AMD graphics switching settings, the nvidia graphics switching setting, and the BIOS’ controls.
If you have a BIOS option, you may simply want to disable that IGPU altogether and remove it from the equation.
I should have clarified that I’ve made sure the iGPU is disabled and the 5070 Ti card is selected in Sketchup’s settings. The user has a single monitor, connected to the dGPU. At this point I’m guessing I’ll have to try older studio drivers…
traditionally the edge and profile rendering is the most stressful part for SketchUp - If you disable edges and lines and it seems improved then you can often identify between whether you are GPU or CPU bound.
wouldn’t surprise me, when sketchup 24 was released (with the new engine), there were problems with AMD chips and transparency.
we had a similar situation on macs, where some brand new M3 and M3pro machines had bugs and instabilities that the older M1 and 2 (and later M4) didn’t have.
I can’t tell you more, but the dev team is working on performance for the next releases. your case might be an interesting one, in the way that maybe your new machines are “too powerful” for su26, but at least they should be made adequate for 27 ?
ping to @TedVitale_SU who might know what to do?
Update: the problem has been solved. The affected user had apparently installed a bunch of plugins and by disabling all of them, the issue disappeared and performance returned to normal. I advised them to enable each of the plugins one by one so that they can pinpoint the problematic one, but for now I consider the matter closed. Thanks for all the input-suggestions everyone.
