Ruby Window Error
#1
I have a component with other nested components. When trying to edit the nested component I get this error; “part of the element cannot be changed within Ruby Window”. I haven’t seen this before. How can I solve this so I can continue to edit the component?
#2
This sounds like it comes from an extension that you have installed – one that finds not the best, uncryptic way to tell the user when a problem occurs.
Can you give a hint what extension it could be? If you have no idea, you could try disabling extensions (binary search: disable one half, then the other half and test to find in which half the suspect is, then continue with half of the suspect half…)
http://help.sketchup.com/en/article/1700320
The easiest way to enable/disable plugins is by using the ‘Plugins Manager’ tool that is supplied with the ‘SketchUcation Plugin Store’ toolset… http://sketchucation.com/resources/plugin-store-download
#3
This post was flagged by the community and is temporarily hidden.
