I thought I understood Ruby refinements but now I just realized that a Using statement is required in every file before the module declaration. Is there a way to make a refinement global to a module without adding a using statement to every file?
module Smith
module Smith::Refinements
refine String do
def numeric?
Float(self) != nil rescue false
end
end
end
end
using Smith::Refinements
module Smith
def self.test1
return '1'.numeric?
end
end
Smith.test1 #returns true
#execute this as a separate file or paste into ruby console separate from above
module Smith
def self.test2
return '1'.numeric?
end
end
Smith.test2 #returns undefined method
I don’t think so. There is an explanation for it somewhere.
Also be aware that the implementation is evolving. In Ruby 2.0 the using
statement needs to be in the top level ObjectSpace. But in later Ruby versions, you can put them inside class blocks and the refinements will only apply to that scope within that file.
EDIT: It looks like class scopes were added in Ruby 2.3 which SketchUp does not yet use.
(SketchUp 2018 still uses Ruby 2.2.4.)
Note that the documentation for refinements has lagged behind the actual implementation details.
I think last I looked, that the docs still stated that using
statements need to be in the top level even though module and class scope was implemented.
Other 3rd party blogs etc.
… see full Google search …
