MMmm I think I will try writing infos directly in the file. 1, 2, 3, Go!
Write infos directly to file, give again only 1 result.
So it’s not the array the problem.
Well I think I have to check entity.definition.entities
from Aerilius.
def attrib_piece(defs, f)
iPiece = "" #Infos piece
dicts = defs.attribute_dictionaries
if dicts != nil
dicts.each{ |dict|
if dict.name == 'dynamic_attributes'
dict.each{ |key, value|
iPiece = iPiece + "," + key.to_s + '=' + value.to_s
iPiece[0] = '' #Supprimer premier caractère (,)
end
end
f.puts(iPiece)
end
def lister_pieces(ents, f)
ents.each{ |ent|
attrib_piece(ent,f)
if ent.respond_to?(:each)
ent.each{ |en|
lister_pieces(en, f)
end
end
#-----START-----
mod = Sketchup.active_model
ents = mod.entities
#ents = mod.selection
#Write file
modelPath = Sketchup.active_model.path
filename = File.basename(modelPath, '.csv')
if filename == ""
filename = "Sans titre"
end
save_path = UI.savepanel "Enregistrer rapport CSV", modelPath, filename.chomp(".skp")+".csv"
if save_path != nil
File.open(save_path, "w+") do |f|
end
end
WORKING!!! with the help of Aerilius, by the ents = mod.definitions
Here is my final code for people who need it!
#DEFINITIONS
iPiece = “” #Infos piece
if dicts != nil
dicts.each{ |dict|
if dict.name == ‘dynamic_attributes’
iPiece = iPiece + “,” + key.to_s + ‘=’ + value.to_s
iPiece[0] = ‘’ #Supprimer premier caractère (,)
end
end
f.puts(iPiece)
end
ents.each{ |ent|
attrib_piece(ent,f)
ent.each{ |en|
end
end
#START
filename = File.basename(modelPath, ‘.csv’)
if filename == “”
filename = “Sans titre”
end
save_path = UI.savepanel “Enregistrer rapport CSV”, modelPath, filename.chomp(“.skp”)+“.csv”
if save_path != nil
File.open(save_path, “w+”) do |f|
end
end
Of course thanks a lot for all people who help me! TY TY
I’m wondering if I need to purge the components before I run the script?
Purging removes component definitions that have 0 instances. If you just want to ignore them, you can also do:
ents = mod.definitions.select{ |definition| definition.count_instances > 0 }
Scramble is the only way the encrypt script?
Yes, in the end SketchUp (the ruby interpreter) must still be able to unscramble and interprete it.
The alternative is to develop the essential parts in C/C++ as Ruby extension and compile it to binary code (for all supported platforms), which is a lot harder to disassemble.
Where i can get the Scramble software?
you need to register as a developer and submit your extension which is returned scrambled…
there was to much hacking when it was publicly available…
john
