I have a roof face with dormers(no bottom faces). While trying to save the model using “Sketchup.active_model.save” method, this face is getting split up into small faces.
Before save, the roof face had only one face
Please help to trouble shoot what happens when save method is executed, that is causing the issue.
Taking a wild guess without seeing the model…. The plane of the roof and the points where the dormers intersect are not coplaner by a very small amount . When you save the model the “automatic fix the model” creates the hidden lines your seeing. You really should post the model so people can check it to be certain.
If this is an API/Developer type issue, please put it in the correct category, otherwise people will waste their time giving you answers you don’t want.
It also appears to me to be a question about a small inaccuracy in the points around that face. I would redraw the geometry from scratch, and the issue is likely to disappear.
There are no API options to disable this check when saving, and even if there was it would still happen when saved manually. The root cause is the geometry.
This why I said it needed to be moved to the correct category, if you are looking for a coding answer it suggests that your created the model using code, and if that is the case there is something wrong in the creation process.
Non coding people will only be able to suggest you correct the model.
I agree, but they at least have a chance of seeing what might be causing the issue if it is code that is creating the geometry to begin with.
At this stage, with nothing to go on but a screenshot, it is anyone’s guess.
Can you post the model/component please? I’d be curious to check the points that connects with the roof face vs how accurately they lie on the plane of the face.
Thanks a lot guys. The issue is - some bottom edges of dormers were not sitting properly on roof.
All of your suggestions are very helpful to understand the issue.
