Revit importer 1.2026.1.10 doesn't import Revit 2027 files
Revit 2027 files still cannot be import in Sketchup. I have to export in dwg from Revit 2027 in order to import files in Sketchup. This is a step backward unfortunately. Any idea when this official extension will eventually be updated ?
Revit 2027 support is in Labs right now. If you would like to test it, send me a DM and I can add you to the programme (we are actively looking for users who are interested in testing new Revit workflow features).
Tiago already covered your question, but for your knowledge @ralphOne, the 2026 in 1.2026.1.10 refers to the Revit version supported so that people know exactly what Revit support can be expected.
It is a little confusing as we usually release the latest Revit support at about the same time as a new SketchUp release, so understandable that people might think it refers to that instead, but that timing is just coincidental (and we will always support the latest SketchUp around release as we are fully aware of those timings and have access to internal test versions). I did consider if we should put both versions in the number, but decided that for example 2027.2026.1.3 would just be way more confusing!
Also this timing of adding support for latest Revit version in Q4 is as usual due to the library we use and is not expected to change any time soon - see Revit 2024/Revit 2026 not working with SketchUp Studio 2025
Dan
Thank you for this detailed explanations.
Hey Tiago! I saw your post about the Revit 2027 Importer being available through Labs. I have SketchUp Studio and am currently unable to import our Revit 2027 models. I’d love to join the beta and help test it. Thanks!
I paid for SKP studio to be able to import revit models. Running into issues not being able to import models from revit 2027.
Revit Importer with support for Revit 2027 is out in Extension Warehouse, you can download it here: SketchUp Extension Warehouse
Thank you for the advice. I installed it and it is OK so far, just import a medium Revit 2027 file with no problem except the same glitch with some hidden faces.
