Hi,
I am looking for a plugin that can do the following create reveals and/or grooves on a face. I am working on a concrete tilt up project, and there are probably thousands of reveal lines at various elevations, and I need a way to speed up the process of detailing these reveals. Doing it manually will take all week.
I am aware of the 1001bit tools horizontal groove tool, however my issue with this tool is that it does not maintain the solid nature of the object it is extruding, instead it will make subgroups and open meshes to do it’s extrusion… not to mention rotating hundreds of tilt up walls back and forth to work within the “horizontal grooves only” functionality constraint will burn a lot of time.
I am also aware of tools like latticizer, which for many reasons will not work. It’s just too basic.
Ideally the tool I am looking for will work similar to the 1001bit tools groove tool, but be able to maintain solid components and also work in more than one dimension with multiple edges selected.
Any help here is greatly appreciated, thanks!
