Restore classic Water materials to default Materials library (marine / boat design)
I am a marine and boat designer using SketchUp Desktop daily (annual subscription, currently SketchUp 2026). From SketchUp 2025 onward, the classic Water materials disappeared from the default Materials library. Nearly all of my work is boat, marina, and waterline modelling. A simple water material is essential for design presentation and client work. 3D Warehouse Classic Materials is only a workaround. Please restore Water (and ideally related marine / environment materials) to the default Materials library in SketchUp 2026 and later, even a small PBR water set in the default tray would help.
the moved to the 3d warehouse a couple of years ago.
in your material panel, click on the warehouse logo. and check the classic materials.
water is a lot more complex than making things rough or metallic. it’s about reflection, refraction, translucence.
we’ll probably have artificial lights before actual pbr water, if.
you can also check the 3d warehouse in general
