I want to be able to change the size of an object, in this case an LCD Monitor which is an imported .skb file.
Got pretty good at use of the ruler for re-sizing however I want to be able to change the width to say 20"W x 13"H and when I change one side it works fine BUT also changes the other proportionately and incorrectly.
Most likely you can just open the component for editing to get to the edges and faces. Then use a selection box around one side and use the Move tool to move the selection.
You have to get down to the base geometry. It sounds like you’ve got some nesting in the component so you’ll have to get inside each component/group. Or just exploded all the components/groups inside the parent before resizing.
