Yes. It can. You’ve uploaded the backup version of the file, not the working version. You should be uploading the one without the ~ in the file name.
how do I do that sorry?
Upload the one the one without the tilde to DropBox in the same way you uploaded the previous file.
FWIW, you have a lot of incorrectly oriented faces in your model. There should be no exposed blue back faces.
And it might help if you’d mentioned that the bright textures are location images.
yea its also the sky that has lots of light
I dont know why its emissive
I’m confused what you mean about the file sorry
It renders just fine here - it told me I needed to upgrade the file from an older version of V-Ray
Maybe try updating your V-Ray to the latest version.
Also, you are using SketchUp 2022 with Ventura, which is not supported - you need to be using SU2023
And as V-Ray asked me about those updates, you are probably using a version of V-Ray that is also not compatible with Ventura.
perfect thanks so much
