Removing classic license from a formated computer
Hello.
I’m having trouble reinstalling Sketchup 2019 after formatting my SSD. I had this license on my notebook and desktop. As I forgot to remove the license before I finished installing the old desktop, I now get the message saying I cannot install on another machine.
And there’s no way to get support, because they say I’m not allowed to support anymore.
Perfect way to force another purchase…
Any ideas on how to fix this, guys?
Removing the license before you reformatted your computer’s drive would have released it at the license server. You might get @colin to take pity on you and release your license for you.
Your choice to allow your support to lapse means you are taking responsibility for this kind of thing. Might make a note to remove the license before reformatting if you have to do that in the future.
The classic license is normally tied to the User name and the Host ID or Ethernet Adapter which is usually on the motherboard. You probably changed the name of the account, so you need to create a user account with the same name as before and then add the license there. Then remove it and use it on the new account.
FWIW, you are allowed to activate on two machines, but also get a spare activation, so there is at least one other machine with your license info out there…
btw, with the subscription plan, you get control of the activations yourself and can easily switch between all versions that use the sign in activation (2019 and up)
Do you still have a problem? It looks like you have been deactivating and activating. If you do still have a problem, I made an adjustment that may help. Try again.
Hey Colin. It’s activated on my two machines now and I believe your tweaks made a difference. Many thanks!!!
Same issue happened with me resulting from a catastrophic hardware failure… it happens… Colin came to the rescue then too… :slight_smile:
Bonjour
Je suis nouveaux sur Sketchup Community
J’ai le même problème que @PabloCesar sur la version pro 2018
Impossible de trouver une solution et pourtant j’ai cherché
Aidez moi svp
Your 2018 license looks like it should be working ok. You also have a 2020 license, is there a reason you need to stay using 2018?
Bonjour
J’ai une version classique de 2018 mais pas 2020!
Après avoir changé des composants de mon PC sketchup ne fonctionnait plus
J’ai désinstallé 2018 et réinstaller parce que le message était “créée sur un autre ordinateur” ça n’a rien changé
Du coup j’ai installé 2022 avec période d’essai 30j pour pouvoir travailler en attendant de trouver une solution
Mon chef a pris une licence classique 2018 et passer à une version plus récente obligerai à racheter une licence ou prendre un abonnement
The error message was because you taken the old PC license and put it onto the new PC. If you open 2018, remove the license, then add the license again, it will work ok.
You do also have a 2020 license, but make sure that you have finished activating 2018 before you activate 2020. When you activate 2020 you are committed to using 2020, and won’t be able to activate 2018 on another new PC.
I have had an email sent to you, with your 2020 license details. Don’t use those details for activating 2018, you will need the 2018 license values.
En mettant les détails de la licence 2018 ça ne marche pas.
Installer sketchup pro 2020 engendrerai des frais et je (mon chef) serai obligé de prendre une version avec abonnement et non classique comme j’avais. Il me semble que à partir de 2020 il n’y a plus de licence classic
Il me faudrait la licence Sketchup Pro 2018 que mon chef a payé
—— translating ——
Alors, ce que Colin explique, c’est que tu as direct tenté d’installer la licencer 18 alors qu’elle est encore rattachée à l’ancienne machine. Si tu as toujours accès à l’ancienne machine, tu peux y désactiver la licence, et du coup elle sera dispo.
Il te dit aussi que rattaché à ton mail, il y a déjà une licence 2020. pas besoin d’en racheter une, elle existe. Mais attention, si tu actives la licence 2020, la 2018 ne sera plus utilisable (enfin activable)
Il a fait partir un mail (sur ton mail donc) avec les infos de ta licence 2020 déjà existante, mais là encore, si tu t’en sers, la licence 2018 ne pourras plus être activée de nouveau.
Du coup, ton chef a payé une licence pro 2018, mais visiblement aussi une 2020, et Colin t’a envoyé les détails par mail. Parce que les licences classiques étant rattachées à des machines, si SU ne reconnaît plus ton nouvel ordi, j’ai bien peur qu’elle ne soit coincée, et plus moyen de la remplacer (ça n’existe plus)
Donc vois dans son mail si tu peux installer 2020 (vu qu’une licence 2020 existe rattachée à ton mail)
Bonjour
C’est bon j’ai réussi!!!
Merci beaucoup à vous et Colin pour cette aide
J’ai pu installer 2020 avec les codes que Colin m’a transmis
Impeccable, bonne modélisation alors !
it worked. Huzzah ! :slight_smile:
