The rectangle and line commands are not working correctly. When I take the rectangle command, it grabs the first point but is not catching the last point.The last point is catching on with the free will, it was only happening in the rectangle command but now the line command is facing the same problem.
Tried changing your mouse? Sounds like a dying left click button…
I have already changed mouse.
Do you mean you are having problems with snapping?
Maybe. Tell me what should i do to end this problem??
The video below shows how it normally works. As you get near a snap point, its “magnetic pull” recognises its proximity and you are told what kind of snap point it is. In this case, they are Endpoints.
Are you saying that that works for you on the first Endpoint but not the next? In short, that you are losing the magnetic pull mid operation?
