this file format was skb but i renamed it skp. i have no that file file. this file drawing my friend laptop he use sketchup25 verson.
At this point you’ll have to start over.
Please correct your forum profile, then. You are NOT using SketchUp for Schools. Ask him if it’s cr acked. That may be the cause of the file corruption.
This file do not open the sketchup 25.
When i open the file in sketchup 25.
“Open to feiled “ this tex view work place
Pls recover this File
Is this the same file you shared previously? You need to make it accessible to us.
I told you before there’s no recovery available on the file.
Hi is there a way to recover this file? It says “failed to open document” plssssss https://drive.google.com/file/d/1D1hPbbA2uKd_O2HvLsKYW5dfkcxI3y87/view?usp=sharing
That’s a relief! Can I pleasee ask for a saved as copy? I would like to try to open it again on my pc. Thank youuu
Do what I did. Download it from your link and open it.
It works! Thanks!
Good.
BTW, you should clean up your model before you work on it anymore. I fixed incorrect tag usage …
… purged unused content …
… and reduced the excessively huge textures to a reasonable size.
That reduced the file size by more than 35%.
You should be ensuring that all edges and faces are untagged from the begining. There is no reason to be hoarding all the unused components and materials. It just makes your computer work harder.
My skp and skb files seem to be corrupted. I would appreciate to know if it would be possible to recover https://drive.google.com/file/d/1m9grB-swZGRjdv9pATzoagtLOlL2kVhB/view?usp=sharing I have an older backup but getting this one back would be great or at least know if it’s lost so i can move on. @DaveR
The last two thirds of the file contains nothing but zeroes. There’s no way to recover anything from it.
Trying to figure out where things went pear-shaped. Where were you saving the file while working on it? Which version of SketchUp are you really using? Your profile says SketchUp for Schools which is a web based version for school children and 2025 Desktop which is not SketchUp for Schools. If you are using SketchUp for desktop why aren’t you using SketchUp 2026? Are you using a cr acked version?
No i’m at school right now, i think its sketchup pro 2025 on the schools computers (I sped through setting up my account) I was working on the file and accidently took out the usb key it was stored on. Thanks for the confirmation tho.
That’s definitely going to cause problems. You really shouldn’t be working on the file while it is saved on the USB key. You should copy it to the internal drive to work on it. After successfully saving the file to the internal drive, copy it back to the USB key.
Please correct your forum profile. The wrong information there just gets in the way of help you.
Thanks for the advice, sad that my bad habits finally caught up to me lol. Does my profile / sketchup version make more sense now? I figured it would be the higher ED version.
Yes although the operating system should be Windows 10 or Windows 11 depending on what the machine has. And “windows” is not a graphics card.
I have a problem with the file. I would be very grateful if someone could help me. This is what it says.
It’s missing some information. Where were you saving the file while working on it? Did you check the .skb file to see if it would open? Your rpofile indicates SketchUp for Schools which is a web based version for school children. This file wasn’t created in that version. Is it really a cr acked version of SketchUp 2023?
Hello @DaveR, I get the error: “This does not appear to be a SketchUp model!”. The issue may have happened during a save (possibly a crash or interruption), but I’m not 100% sure. Can you help me to fix that, thank you. This is my file:
Nothing to recover from either file. The .skp contains nothing but zeroes while the .skb file is about 76% zeroes.
You indicate in your profile that you are using a Classic license for SketchUp 2024. Does that mean it’s a cr acked version?
