@basbva, thanks for the detailed reports! An update on each:
Nested folders showing up again in the render (when you make the first child visible again): not fixed in 0.9.103 yet. I’ll try to reproduce it with nested groups and tags and get back to you. If you can share a small model where it happens, that would help a lot.
The freeze while extruding with the live render on: since it only happened once, I’ll keep an eye out for it. If it happens again, Rayscaper’s log right after it helps: Extensions > Rayscaper > Export Logs for Support, or the files in ~/Library/Application Support/Rayscaper.
The render not updating while you move objects: that’s a difference between the Mac and Windows: on the Mac the render only follows once you release the object. I’m looking into making it follow while you drag.
Thanks again, this kind of feedback is exactly what I need!
I’ve attached a little test model I use myself, containing two cubes with nested groups by tag folder. Visibility can be controlled through either their individual tags or their parent folders.
Thanks for the model, that made it easy! I could reproduce it on Windows too: when a folder became visible again, Rayscaper also showed the folders inside it that were still hidden. It’s fixed for the next beta (see the before/after below). While testing I also fixed moving tag folders into or out of hidden folders, and deleting a nested folder.
Until the next beta, toggling the inner hidden folder off and on again brings the render back in line with SketchUp.
A new Mac beta is up: Rayscaper 0.9.104. Same link as before: Rayscaper for Mac
It brings the Mac up to date with the latest Windows release. What’s new since 0.9.103:
Light presets with real brightness: bulbs, downlights, an LED panel, a window, the sun and more. You set a light’s intensity in lumen, cd/m² or lux, and a new light starts as a real one, like a 60 W bulb.
Lights are easier to place and aim: while a light is selected, SketchUp shows the cone of a spotlight, the radius of a point light and the spread of an area light. The new Aim Light tool turns a light towards the point you click, and right-clicking a light gives a Rayscaper submenu: Edit in Rayscaper, Turn Off/On, Aim and Change Type.
More light controls: change the size of an area light in Rayscaper’s light editor, and copies of a light in SketchUp keep its settings.
Material ID and Object ID render methods, and render passes (Material ID, Albedo, AO, …) in File > Render Scenes…
Translucency in the Standard material, for curtains, lampshades and leaves lit from behind. Thin glass modelled as a single face now reflects too.
Fixes: hidden nested tag folders stay hidden when their parent folder is made visible (thanks @basbva for the test model!), plus fixes for crashes when removing lights, groups and components while rendering, and a notification instead of a crash when the GPU runs out of memory on a very large render.
If you installed an earlier beta: install this one over it, then restart SketchUp.
Thanks to everyone testing, keep the feedback coming!
A new Mac beta is up: Rayscaper 0.9.105. Same link as before: Rayscaper for Mac
It brings the Mac up to date with the latest Windows release, plus a few things that Windows doesn’t have yet. What’s new since 0.9.104:
Render in the SketchUp viewport: Extensions > Rayscaper > Render in Viewport draws the render inside the camera frame of the SketchUp view, so you can model and watch the result in one place.
Rayscaper speaks your language: Dutch, German, French, Spanish, Italian, Japanese and Simplified Chinese. Rayscaper follows the language of SketchUp, or pick another one with the Language setting. Chinese, Japanese and Korean text now shows up on the Mac too.
Presets for the Post Processing, Environment and Render tabs, including the sky conditions, and you can save your own. (Mac first, Windows gets them in the next release.)
Your own keyboard shortcuts in a Keyboard Shortcuts tab of the settings. (Mac first as well.)
Sharper details after denoising: fine, low-contrast textures like dark wood grain in the distance no longer get smeared out.
Lights in reflections: area, spot and point lights with a size now show up in mirrors, glass, chrome and glossy surfaces.
Fixes: textures of materials painted on groups and components render again, texture changes and Position Texture show up right away, objects stay in place after editing inside an open group, a missing normal map no longer darkens a surface, picking a 16K HDRI no longer quits SketchUp, and SketchUp’s Undo can no longer take your Rayscaper settings away.
If you installed an earlier beta: install this one over it with the Extension Manager, then restart SketchUp.
A new Mac beta is up: Rayscaper 0.9.106. Same link as before: Rayscaper for Mac
What’s new since 0.9.105:
No more crash next to other extensions: starting a render could crash SketchUp when an extension such as Unreal Datasmith was installed. Such an extension loads its own copies of libraries that Rayscaper uses too, and macOS handed those to Rayscaper. Rayscaper now ships its libraries under names of its own, so they can’t get mixed up. Thanks to the tester who sent their logs!
A calmer, more polished interface: clearer text hierarchy, quieter controls with their values lined up, dropdowns with readable lists, and a status bar that shows what Rayscaper is doing and, when a render fails, why.
Faster value editing: drag a label to change its value, double-click a slider to type one, and type values with units (35 %, 2 ft, 90°). Right-click a setting in Post Processing or Render to reset it to its default.
Feedback when you save: saving a render, preset or material shows a notification with Show in Folder, and errors tell you what to do next.
Scene tabs set the sun: selecting a SketchUp scene tab now also sets the sky to that scene’s time and date. Before, it kept the sun of the previous scene.
Rayscaper 1.0.0 for Mac is up, out of beta together with Windows. Same link as before: Rayscaper for Mac
It brings the Mac up to date with the Windows 1.0 release. What’s new since 0.9.106:
Grass material: paint a face with it and Rayscaper grows real grass blades on it in the render. Presets for a mowed lawn, a garden lawn, a meadow, dry grass and artificial turf, with mowing stripes, and Wind to lay the grass over one way. The online material library has thirty Grass materials to start from.
Fur material: shag rugs, sheepskin, faux fur throws and plush cushions grow real strands in the render. An image texture colors every strand, so a patterned rug keeps its pattern.
A new look: the render window has calm dark surfaces, clearer selections and a new font.
Smoother navigation: the render follows the camera faster while you navigate or change the model, and the status bar shows what the renderer is doing while a render starts.
Two-Point Perspective views render as SketchUp frames them.
Fixes: soft edges of PNG and TGA textures with transparency no longer turn dark, and changing the model while a CPU render runs no longer crashes.
Good to know: the very first render after installing prepares the GPU of your Mac. That can take a few minutes, with “Preparing the GPU” and its progress in the status bar. Rayscaper isn’t stuck, let it finish. The first render with a Grass or Fur material does this once more, after that renders start right away.
Thanks to everyone who tested the Mac betas, your reports made this release!
I saw a complaint from macOS, about SUEX_SCFLibrary.bundle. I had to go into settings, privacy & security, and give it permission to open. I also had to enter my Mac password. After that rendering started.
The SUEX_SCFLibrary.bundle is part of the SketchUcation tools. We use it for licensing checks. I suspect, that unlike Rayscaper, this bundle is not notarized (signed by an Apple developer account), hence the operating system is flagging it as a security risk.
Allowing it is safe and is required for your license to be recognized. I’ll work with the SketchUcation team to get this notarized.
