Quicker way to get the partial outline of a spherical object, to use with 'follow me tool'?
I was able to successfully create the notch for the balls in an axial bearing to rest in.
The video briefly documents the step I had to take to create the notch. I was wondering if there was quicker way to obtain the notch?
The part that involved getting the outline, suggests that it may be done in a qucker way. Using the line tool resulted in taking longer than it should and I was more likely to end up making a mistake.
skp file: 038_axial bearing.skp (2.7 MB)
Are you asking how to make the race? Iā€™d have drawn the cross section and used Follow Me to sweep it around a circle.
If you want the profile of the ball, turn on hidden geometry and select the edges, or even draw an edge across and delete the rest.
Profile
