Question about DC copy/paste and Component Attributes in SketchUp
Within our company, we have been using SketchUp for quite some time to make our lighting models available to architects in a correct and usable way.
For this purpose, we use templates that we created ourselves. In these templates, we always had an object from which we could transfer the required Component Attributes. We did this using the DC copy/paste function, so that we immediately had the complete list of attributes for our lighting models available.
However, I have noticed that this function no longer seems to be available. Could you please help me with this, or let me know whether there is an alternative way to transfer these attributes?
Thank you in advance for your help.
This seems to describe an extension embedded with the template and older version.
Attributes can be discovered and arranged with the report writer, this would make sense as the arrangement would be saved to the template. You can generate the report via file menu
It would be helpful if you could share the template (private message if sensitive) and method you would use to get this information.
