As a retired person I enjoy tinkering around but buying a License for the Pro Version is unfortunately not in my budget. But the free version Make 2017 serves me well so far.
But today I am reaching a limitation I can´t think of how to create what I want.
Basically I want to pushpull an opening in a irregular object. I can pushpull it but at the other end it doesn´t cut through but creates a kind of tube. I am adding a file as a sample.
Does someone having an idea or did I reach the limits of Make 2017?
If the face you are trying to punch is not parallel to the face you are pushing against it, a hole will not be cut. This is a general property of all SketchUp versions. You could push past the other face, select the walls of the “tube”, use the Intersect Faces command and then delete everything that does not belong to the “hole”.
