I’m quite new to SketchUp and am experiencing some issues when importing DXF or DWG files that I’ve exported from Visio. When I Import a file, the arcs seem to be misspositioned/missized and are not properly connected to each other.
The original file though seems OK, because when I Import the same file into a Portal for metal laser cutting, everything looks good.
I’m sure there are experienced users out there who could give me a hint.
Very appreciated!
what does the SU Element Info say if selecting an entity?
Check the content with the free Teigha Viewer f. WIndows & Mac OS first and ensure, that content is made of clickable vector elements and not of a dumb raster image.
It might be a size issue. You could try using a larger import unit (Centimeters instead of Millimeters, for instance) to get better accuracy. You can then scale the result back to intended size in SketchUp.
