Bonjour, j’utilise sketchup depuis quelques jours, tout aller bien mais là j’ai un soucis avec l’outil rectangle qui ne fonctionne pas. Tout le reste fonctionne mais pas l’outil rectangle. Il y un message d’erreur “pas un solide” quand je veux l’utiliser.
Merci d’avance
Translated by the Goog:
Hello, I have been using sketchup for a few days, everything is fine but now I have a problem with the rectangle tool which does not work. Everything else works, but the rectangle tool does not. There is a “not a solid” error message when I want to use it.
Please show us what you are trying to do. Give us screenshots and even the .skp file.
The “Not a solid” message has nothing to do with the Rectangle tool. The Solid Tools and Outer Shell require solid components or groups to work but a simple rectangle or ungrouped geometry will not be solid.
