Problema: Este modelo não parece ser do SketchUp
Este modelo não parece ser do SketchUp. parapreceu para mim, preciso de ajuda para recuperar, vi nos canais que devo mandar o arquivo aqui, mas não consigo pelo tamanho, alguém consegue me ajudar???
(post deleted by author)
Your file contains nothing but zeroes. Here it is in a hex editor.
Do you have the .skb backup file? Try changing it to .skp and see if it will open. Have you also been saving to your Trimble Connect storage which is included with your Pro subscription?
Where have you been saving the file while working on it?
já tentei de tudo, não consigo recuper, essa é minha ultima espernça de consguir recuperar ele, pelo .skb tem como fazer essa revisão pra ver se consigo recuper por ele?
Translated by Google:
There’s nothing in the .skp file to recover. Change the .skb file to .skp and see if it will open.
não abre, aparece com falha ao abrir o arquivo
I expect you’re out of luck, then. Were you working on the file saved to an external drive or to the cloud? Did you have a power failure or some other event that affected the computer?
ele ta salvo na nuvem, em um drive online, o programa simplesmente fechou sozinho, deu bugsplah e quando eu tentei abrir ele novamento começou a aparecer essa mensagem
This diidn’t translate well but I think you are saying you were saving and working on the file while saved to the cloud. This has been problematic for many users and they’ve ended up with the same empty files you have. Best practice is to save the file to an internal drive while working on it. If you need to have the file in your online drive, copy it to there after successfully saving it on the internal drive.
You should also be periodically saving the file to your Trimble Connect storage so you have additional backup copies in case something goes wrong like it did this time for you.
As far as that model is concerned, your best option is to start over.
4 horas de trabalho perdido então, mas valeu, existe alguma outra forma deu tentar recuperar ele?
No. There’s no way to convert a file full of zeroes into meaningful data.
Obrigado por tentar ajudar, vou recomeçar
You’re welcome. Sorry it isn’t better news.
This topic was automatically closed after 180 days. New replies are no longer allowed.
