Problem with the parametric “Dimensions” in the SketchUp
#1
How to get “Dimensions” to work in different planes?
Maybe there alternative component or plugin.
I work in the SketchyPhysics.
Link the plugin “SketchyPhysics” - http://sketchucation.com/forums/viewtopic.php?p=536443#p536443
Project.skp (238.5 KB)
#2
Did you try using the AxisTool to temporarily align the model axis with the rotated component instance ?
#3
Temporarily yes, ok. But, the position of the object changes dynamically because I work in SketchyPhysics
#4
Ufortunately, the parameters “Dimensions” changes dynamically good run only one planes.
#5
… then create a group, and put the dimension and the component instance inside the group together. The SP should rotate both together.
#6
in this case, the “dimension” will not change. It will be static.
#7
I need dynamics. I want to see the distance in movement and in the space.
#8
I do not have any problems in SU2015 without Sketchy Physics. The dimension rotates with the object it is attached, and changes size dynamically as I scale or stretch the object… These are called “Associative dimensions”.
Sketchy Physics must have broke something.
#9
#10
Ah… I see. You are going between separate objects.
Yes I think this may be a known issue.
