Hello there,
I have made a model of our apartment that I.m trying to print.
Setup:
I have Sketchup Make, export extension for *.stl files and I have tried to import to a 3D-printer it doesn´t make any errors but there isn´t any model on the simulated board in the 3D-printer program when it is imported there.
I have tried and suceeded with a cube no problem there so logically the problem is wit my apartment model.
Can anyone please help me. The model is attached to this message.
Sincerely
/IronoakLägenheten med väggar.skp (107.7 KB)
If you triple click on one of the walls, it will select everything that is connected. Right-click and make it a group or component. Do the same for the other two connected walls. Note in the entity window that this now says that the groups (or components) are solid:
Using the STL exporter, make sure to un-check the “Export selected geometry only” option.
Or select the three sets of walls and check the box prior to exporting.
Imported into MakerBot:
Thank You,
So far so good, but when I preview the file in the MakerBot program there is nothing there:
/Ironoak
Hmmm … I had the same problem. I can’t even get it to preview a simple cube. Which is odd. If I try to run a preview a second time, it tells me it can’t find the file. However, I opened it in Slic3r and it acts like it should:
I uploaded it to Shapeways and it looks fine there, as well:
I also uploaded it to the 3D Warehouse and used the iMaterialise STL converter, but it still doesn’t give a print preview in MakerBot.
