Problem with hdri in vray for sketchup
Do you have any idea why the model appears so small relative to the HDRI? No matter what I do or select, I can't seem to scale the HDRI down. Right now, the house looks like it’s sitting on the ground, but it’s only about the size of a human palm compared to the HDRI. I’ve tried using several different HDRIs, but the result is the same for all of them.
You use HDRI for lights and shadows. You could use a Finite Dome HDRI for a bit more control; otherwise, for the background, you can use other methods (such as planes with images).
Did you format the text as code to make it harder to read?
