Problem with block axis
I have problems with this block I have downloaded from the warehouse. I really want to use it in my design and as you see the object is not aligned with my general axis. One side can be aligned but the other is never aligned with the other side. Does anyone has any solution?
Thank you!!!
look for some hidden geometry
Explode all the groups in the model then regroup the entire thing.
The new group should be aligned with your current axis.
You can change the component axes to align with whatever you like- open the context menu and choose “Change axes” to whatever alignment you like.
