I’ll try to summarize, there is quite a lot of code, I did my best to put useful comments.
I have a litte workaround which consists in calling PTClayWall 2 times and creating only one scene per call, and hiding the inner panels in the second call. It then gives me the result I want but still that is quite unsatisfactory. Thanks for your help anyway.
// this is the function called to generate the LODocument
int PTClayWall::makeLayout(PTLayoutMaker& maker)
std::string zou = PTString::getFileNameWithoutExtension(maker.getFileName());
std::string num = std::to_string(maker.getElemCounter());
std::string file1 = zou + "_tmp" + num + ".skp";
std::string file2 = zou + "_new" + num + ".skp";
// that's the group representing the wall I want to isolate
SUGroupRef g = getProductionGroup();
SUComponentInstanceRef c = SUGroupToComponentInstance(g);
SUComponentInstanceSaveAs(c, file1.c_str());
SUModelRef newModel = SU_INVALID;
SUModelCreateFromFile(&newModel, file1.c_str());
// see function hereunder. As explained in my first topic, I basically create 3 layers, one for the woods, another one for the outer panels, and a last one for the inner panels(actually it is composed of clay)
PTLayoutMaker::createLayers(newModel);
// first scene without the inner panel(clay)
SUSceneRef frontScene = SU_INVALID;
SUSceneCreate(&frontScene);
//see function hereunder
defineFrontScene(newModel,frontScene, "assemblage");
std::string prd = PTMaterial::getClayCode();
PTLayoutMaker::hideLayer(frontScene, prd);
//second scene with the inner panel(nothing gets hidden). My first guess would be that as both scenes share the same layers, the issue comes from here
SUSceneRef frontScene2 = SU_INVALID;
SUSceneCreate(&frontScene2);
defineFrontScene(newModel, frontScene2,"enduit");
SUResult saved = SUModelSaveToFile(newModel, file2.c_str());
if (saved != SU_ERROR_NONE) std::cout << "time for bed" << std::endl;
SUModelRelease(&newModel);
std::remove(file1.c_str());
// this is the function used to generate the LODOcumentRef, which is a member variable of object maker. This is the last function I quote
maker.makeLayouts(file2);
std::remove(file2.c_str());
return 0;
//After this call, i generate a .pdf file using LODocumentExportToPDF
//The LODocumentRef I use contains only one LOLayerRef:
// LODocumentCreateEmpty(&_document);
// LODocumentAddLayer(_document, false /* shared */, &_defaultLayer);
// LOLayerSetName(_defaultLayer, "Default");
//This is the functions used to create my 3 layers. The model passed in argument is the one containing the single wall.
void PTLayoutMaker::createLayers(SUModelRef& model)
size_t oldnlayer;
SUModelGetNumLayers(model, &oldnlayer);
std::vector<SULayerRef> oldlayers(oldnlayer);
SUModelGetLayers(model, oldnlayer, &oldlayers[0], &oldnlayer);
SUModelRemoveLayers(model, oldnlayer, &oldlayers[0]);
std::vector<SUGroupRef> groups;
std::vector<SUComponentInstanceRef> instances;
PT_skpFileReader::getModelGroupsAndInstances(model, groups, instances);
std::vector<std::string> componentNames;
PT_skpFileReader::getComponentNames(groups, instances, componentNames);
size_t nlayers = componentNames.size();
std::vector<SULayerRef> newLayers(nlayers);
for (size_t i = 0; i < nlayers; i++)
SUSetInvalid(newLayers[i]);
SULayerCreate(&newLayers[i]);
SUModelAddLayers(model, nlayers, &newLayers[0]);
std::string name = componentNames[i];
int ncomp = 0;
PT_skpFileReader::getNumComponent(groups, instances, name, ncomp);
std::vector<SUDrawingElementRef> draws(ncomp);
ncomp = 0;
PT_skpFileReader::getDrawingElements(groups, instances, name, draws, ncomp);
for (size_t j = 0; j < ncomp; j++)
SUDrawingElementSetLayer(draws[j], newLayers[i]);
SULayerSetVisibility(newLayers[i], true);
std::string layerName = componentNames[i];
SULayerSetName(newLayers[i], layerName.c_str());
// this is the function used to create both scenes
void PTClayWall::defineFrontScene(SUModelRef& model, SUSceneRef& scene, std::string sceneName)
int outIndex;
SUModelAddScene(model, -1, scene, &outIndex);
PTCamera2 camera = defineFrontCamera(groups, instances);
SUSceneSetCamera(scene, camera.getCamera());
SUSceneSetUseCamera(scene, true);
SUSceneSetName(scene, sceneName.c_str());
SUSceneSetUseSectionPlanes(scene, false);
//tmp test: it gets even worst: blank pages
SUSceneSetUseHiddenLayers(scene, true);
PTLayoutMaker::copyModelLayersToScene(model, scene);
PTLayoutMaker::showAllLayers(scene);
void PTLayoutMaker::makeLayouts(const std::string& skpfileName)
_elemCounter++;
_ptdoc.setFileName(skpfileName);
LOSketchUpModelRef lo_model_ref = _ptdoc.getModel();
// Get the scene count so we know how many pages we'll need in our LayOut document.
size_t scene_count = 0;
LOSketchUpModelGetNumberOfAvailableScenes(lo_model_ref, &scene_count);
std::vector<SUStringRef> scene_names(scene_count);
for (size_t count = 0; count < scene_count; ++count)
SUSetInvalid(scene_names[count]);
SUStringCreate(&scene_names[count]);
LOSketchUpModelGetAvailableScenes(lo_model_ref, scene_count, &scene_names[0], &scene_count);
// The first name from available scenes is the default scene, we want to skip
//for (size_t count = 1; count < scene_count; count++)
size_t start = 1;
size_t end = scene_count;
size_t step = 1;
for (size_t i = start; i < end; i+=step)
std::string zou = PTString::getStandardString(scene_names[i]);
std::cout << "scene name = " << zou << std::endl;
LOPageRef page_ref = _ptdoc.createEmptyPage();
std::string sceneName = PTString::getStandardString(scene_names[i]);
LOPageSetName(page_ref, sceneName.c_str());
_ptdoc.addEntity(page_ref,i);
LOSketchUpModelSetCurrentScene(lo_model_ref, i);
for (size_t i = 0; i < scene_count; i++)
SUStringRelease(&scene_names[i]);
