Hi, I am having problem to paste components into my model in sketchup pro 2021. I can download them from my documents or warehouse but I can´t se them in my model. This was never a problem with Sketchup 2019. What am I doing wrong?
Thanks
Anna
Thanks
Anna
once you’ve pasted them in, go and check the tags visibility, make sure the tags that they’re using are switched to visible
Check the scale of your model space, you may be zoomed out so far you can’t see them, or in so far they are above or behind you.
Thank you! You were right! I had to scale them up.
Thanks, I had to scale them up.
You shouldn’t really be scaling things up, you should be zooming in and modeling at the appropriate size.
