I am making a Dynamic Component header with sheeting. I need the header to adjust from the center point. I can make that to work. But I need the sheeting offset different on each side. (see picture). Is this possible?Header|690x352
the attachment does not work
most likely it is, please upload the model or private message
there is a frame with header in my warehouse examples, you can edit the opening sub component for different support, is this similar to what you are after? If so can easy help you set an US units type with different supports
Yes, that is what I am looking for. Mine has sheeting on the header. Each side would need the ability to have different offsets. From sheeting to edge of beam
